Who is you email provider, that's the first thing anyone would need to know to try to help you.All of a sudden the ability to block email from certain senders has disappeared. When I google of whatever it tells how to do it, which is how I always did but it is gone now. How to restore it?
You most likely downloaded an update to either your computer system/phone system or your specific email program/app which either removed this option or changed how to do it.All of a sudden the ability to block email from certain senders has disappeared. When I google of whatever it tells how to do it, which is how I always did but it is gone now. How to restore it?
I do that but after the ... block senders isn't there any longer.
Here is what is thereUpon clicking the three dots,
What is "there" now?
The feature may be temporarily disabled while AOL performs system maintenance. If that is the case it should reappear around January 2nd.I do that but after the ... block senders isn't there any longer.
SecretMeet is an ad. He will have no control over that.The feature may be temporarily disabled while AOL performs system maintenance. If that is the case it should reappear around January 2nd.
Another possibility is you've reached your limit on blocked senders.
I'm just curious why you are blocking "David Allen" and not blocking "Secretmeet"![]()
I wasn't trying to block David Allen. I had nothing in spam so I just put him in spam so I could show what it does. OK is there a limit on blocked emails? Maybe that is the problem. If I unblock them what then?The feature may be temporarily disabled while AOL performs system maintenance. If that is the case it should reappear around January 2nd.
Since AOL is using the same webpage format, I went into the "Help" section of Yahoo Mail and found this:Here is what is there
Could you unblock a few of the oldest blocked senders, then see if you could block a recent sender. Might not solve your problem but might learn how aol works. Good luck.I wasn't trying to block David Allen. I had nothing in spam so I just put him in spam so I could show what it does. OK is there a limit on blocked emails? Maybe that is the problem. If I unblock them what then?
I did unblock a few and the block is now available. All the blocked emails were in spam. Not sure it did any good anyway. I would block spam and the spam would be right back but with a different email address.Could you unblock a few of the oldest blocked senders, then see if you could block a recent sender. Might not solve your problem but might learn how aol works. Good luck.
The block is on the email address. It will not block by email content.different email address.
That's how they operate. They switch addresses, because they know people are blocking. All you're doing is playing "wack-a-mole" trying to hit a moving target.I did unblock a few and the block is now available. All the blocked emails were in spam. Not sure it did any good anyway. I would block spam and the spam would be right back but with a different email address.
