coryeneks
i have a 48 8n ford and it has started to blow blue smoke from exgaust.is this a big problem and why is it doing this ?????thanks yall..
Blue smoke is usually burning oil. It could be anything from worn or stuck rings to leaky valve seals to a piston with a hole in it.
Have you been using the tractor, regularly, and it just started blowing smoke, or did it sit for a long period, and now smokes when you run it?
Give us more info, and we'll try to ease your worries.
My 8N
In the Ford F head engine, it's probably:
1...Cylinder wall wear (progresses slowly, not overnight)
2...Piston ring wear (progresses slowly, not overnight)
3...Sticky piston rings (this *could* happen overnight)
So...my strongest suspicion is #3.
The bad news...you MAY need an overhaul. The good news...you can probably avoid having to do this by using the "MMO" cure. Search the archives, there's plenty of info there!
Tim
'42 Ford 2N, #9N103775
'49 Farmall Cub, #98040
'53 Ford NAA Jubilee, #NAA-56293
'64 Minneapolis Moline Jetstar 3, #28301626
nnalert Tractor
Maybe that is has seen 1 to many hour and it need to have the engine over hauled, or you could have done something like had a ring brake. If it happen pretty much over night, I.E. didn't do it one day then started doing it the next time you ran it you may in fact have a big problem like a broken ring. I would pull the plugs 1 at a time and see if you can figure out which cylinder it is then do things like compression test etc and maybe find the problem that way but still you will most likely have to pull the head off to fix the problem
Some more things it could be is has it been a long time since the oil was changed?Is there a lot of gas in the oil?Did you change the oil and put a different weight oil in it?Is the air cleaner plugged or full of water?Did it get low on water and run hot?Oil will float on water and if it sucks oil in the carburetor from the breather because it got water in the breather and raised the level of the oil,or if gas somehow gets in the pan by idling a lot with the choke partly closed that can wash the cylinders down and dilute the oil.It could be worn out.If its been hot recently that can make the rings to where they dont have as much tension as they need and cause them to let oil by them.
