Ken Hansen
About three times lately while mowing my BN would act like it was running out of fuel. First time I managed to get back to the shed and before adding fuel decided to check the level as I really thought I should have had enough to mow the back yard.
Sure enough there was at least two inches in the tank when I measured with clean dowel I keep just for that. Stated tractor back up and it ran good and finished mowing.
Next couple times it happened I kept going as it only acted like that for a few seconds then ran good the rest of the lawn. At least one of those time I did look in the tank to see if there was something that would be restricting the flow and bottom of tank looked nice and clean.
Well today with all of maybe a 50 foot by 6 foot strip left to mow it quit again. Cranked a good amount before it fired up and ran good to finish and back to shed. This time I again looked in the tank and saw what looked like blades of grass laying on the bottom of the tank near the fuel fitting hole.
Well I'm a bit on the fussy side so could not imagine grass getting in the fuel tank. So I gabbed one of my flexible finger thins and after a few tries managed to pick a couple of the "blades of grass" out. Once out in the open I could see they were not green grass but little strips of the sealant from when I lined the tank a few years back.
Not wanting to be draining gas on a hot machine that just spent a couple hours mowing on a warm day decided to wait till morning to drain tank and remove sentiment bowl to see if the inlet to that is also partially plugged. The glass bowl looks nice and clean as always but there could be some stuff up inside by the shutoff valve.
