Anonymous-0
Hello Bob.
How are you?
After careful consideration,
Reading your letter.
I want my springs, I want the carb, and the extra throttle body returned.
I have a carburator, that I have personally bored out, After boring it out, I even cleaned it out, replaced everything, it is to the EXACT specs, as the one your friend holds in his possession.
Its the same bore ID, same size jet, same stem, same everything as the one you guys could have reassembled.
I even, went to the extent, to put it on a tractor, ran it, its the most awesome carb we have ever seen.
Like fuel injection it works that good.
It is boxed, it is ready for a lable and dropped off. I will go to the extent of posting the tracking number here.
My clutch rebuild kits for our posi kits, which are available thru me. Cost of $40 per set. +$5 bucks shipping.
Ill be happy to build you a seal. Since one was never offered in the original design, I had to invent one.
I will need the clutch side shaft, brake hub included, with the clutch assembly and the axle shaft.
Box it up, make sure a return shipping is paid along with it.
The seal is $110 dollars. But now comes free with purchase.
Now, when you have the carbs boxed up, tracking numbers provided, we will go to the swap meet.
I will not send a 3rd carb till I know the other 2 are comming back at the same time.
Deal or no deal? Would you like to call a friend?
Ooopps wrong show,,,
I know how these old carbs work, and when the carbs come back, I am going to assemble it as it comes to me,, put it on the same tractor I tuned the COMPLETE carb for,,, and I guarentee, it will run and run good within 10 minutes of installation.
Wanna see a slide show of this carb and how it was built start to finish?
Then, I want you to tell me what it was,, I left out,, in the carbs you have now.
ChadS
How are you?
ChadS
