Bobcat questions
Anonymous-0
HI i am looking to buy a skid steer. I have a low budget so i mostly look at small machines. I have found a bobcat 444 and a 500 for $2750 each and i was wondering if anyone could tell me if one is better and if that is a good price. And just any other information. Thank you
Oh yeah i was also wondering if anyone in the southeastern wisconsin area has a similar machine for sale. Thank you.
I plan to use it for snow clean up general landscaping and hopefully(if i can get a machine to handle it) concrete removal.
I only ask cause in my opinion you cant get one big enough. I have a 1840 Case diesel. Wouldnt want one any smaller. Like you i use mine for general purpose around my place. Landscaping, snowremoval, lifting things off trailer or truck etc. what ever you get you might also consider two buckets. I have bucket with teeth and one for snow (smooth bucket) without the teeth you cant dig..even a pile of dirt thats loose, ya need teeth. Good luck
as mss3020 said get 2 buckets or at least a smooth one and get a set of bolt on teeth that can be removed when a smooth bucket is needed. not the tooth bar they are not that good for hard digging. I have a Toyota sdk7 and love it kinda small but very strong compared to the ones the same size I wish I could find another one to have a spare or even parts
I have a Bobcat M500, it is a 2 cyl Kohler/24 hp, variable speed belt drive, if you plan on using it to dig, especially concrete, plan on LOTS of maintainence, especially $120 belts. The jackshaft parts aren't cheap either. It's not what you need. I use mine for all the easy jobs I can find and it will last me forever. If I'm going to dig, I borrow my neighbors 642B, it's hydraulic drive.
Those are both pretty old machines. I would think that a lot of parts are obsolete. Do you have a budget in mind? A newer hydrostatic model would be a better choice but a decent one will probably cost at least double of the ones you're looking at. A liquid cooled engine is better as well. You could make a cheap cab and put a heater in it for the winter. As far as buckets go, some guys that can't afford 2 or 3 buckets will put the top mount (weld on)tooth adaptors on. They are more expensive than bottom mount but the bottom of the tooth is flush with the bottom of the bucket, so you can still leave a smooth surface without tooth grooves in it. Bobcat usually has the top mount teeth on its buckets. I'm not sure about other makes. What ever you look at, be sure to post on here. It could save you a big headache. Dave
I have a 500 also. It was quite a machine when they were new. I still use it for loading logs on my Woodmizer sawmill.
Dave thank you very much. I didnt know the difference in the teeth mounts so thank you for that info. Unfortunately my budget is maxed out at about $3500 so i think i may be stuck with an older machine. Thank you very much for the info.
Thank you both. i appreciate the advice. That definitely throws a hitch in my path but ill keep looking. Thanks again
