Bobcat S300
Anonymous-0
My buddy has an Bobcat S300 that he would like to put Hi-flow on it because he bought an attachment that requires it. Has anyone ever installed one on a bobcat. He knows it will cost thousands but he is willing to spend it. No one will give him whats it worth in trade-in and it is paid for.
You'll need a higher flow and higher pressure pump for starters. The first thing to do is see if high flow can be retrofitted to a standard machine. The high flow machines usually run a third hose that's used for a case drain found on most high power hyd. motors. Yes, it would cost thousands but he/you better make sure it can be done first. High flow machines might have a totally different hydraulic system from standard machines. Dave
