Bolens 54 deck pto input rpm??
I have a 18071 54" Bolens deck in excellent shape and I was wondering what rpm the input shaft runs at. I would like to make this deck a rear-mount 3-point mower for my Case VA #with a little easy fabricating# but first I need to figure out if it is a 540 RPM deck or not. Thanks.
The rpm speed on a garden tractor is usually a Lot higher than 540. My bolens tube frame tractor spins the PTO at engine RPM, the pulleys on the engine and the PTO are the same size, so its 1 to 1. So, with the engine at full throttle for mowing, that insput shaft is spinning at 3600 RPM.
Other model Bolens tractors do have the PTO rpm for the mower slowed down some, but its still well over 540. Often around 1200 or so. have to determine what model BOlens tractor that was made for, and then find out what that model garden tractor's PTO RPM is.
turning it at 540 probably won't hurt it, but it may not cut very well either.
The #18071 mower attachment was for the Bolens model 1886, 1886S, HT18, HT20, 2086 & 2087 tractors.
I can not tell you what the PTO speed was on these tractors, but I believe it was greater than 540 rpm.
