Anonymous-0
Hi,
I have a question for any machinists out there,
I have a stainless steel heavy wall pipe 200mm inside diameter, 150mm long which has 2 flanges welded on it one top and one on the bottom. I want to bore a 1mm step the from the face of the top flange down 10mm On the inside.(Making the first 10mm from the flange face 202mm diameter)
To bore this on a vertical milling machine , bridgeport type, how would I do it, What is the best way to centre it on the machine table?
I cannot use use a lathe because there is a large bracket protruding from the outside wall of the pipe.
