Box blade and stumps
Anonymous-0
Went out today with the box blade to clean up around some pine trees that have years of pine needles and whatever else is buried there,I found several small stumps the previous owner cut. What a suprise that was! I found out that a box blade will pull a stump totally out by the roots,now when I get grass to grow there won't be any ostacles.By the way a box blade is a GREAT lazy mans rake for neglected areas. Mike
I just rented one to drag gravel up out of ditches and put it back in the road where it belongs. I had never used one before, but I was very impressed with how well it worked. I'm glad to hear you liked yours too.
Zach
You have to be more worried about the stumps that don't pull out. I've seen cheap box blades all bent to shut. I lifted the front wheels of my tractor with loader catching a root. Good thing I was going slow and bought a fairly heavy one. Dave
It probably only worked because they are old stumps and soft wood. I wouldn't try it with a stump from a hard wood tree or that had been cut in the last few years. Most box blades aren't meant for that, but if it works on what you have, good.
