Branded as Montgomery Wards
RedMF40
Not from Iceland!
I’m intrigued by this little tractor. Looks similar to a Cub Cadet. Anyone know if Montg Wards sold Cub cadets under their own name?
I’m intrigued by this little tractor. Looks similar to a Cub Cadet. Anyone know if Montg Wards sold Cub cadets under their own name?View attachment 77438
That's a Gilson. I have one very similar, also branded as a Montgomery Ward. They were heavy built with a cast front axle. Belt drive to a cast transmission. The one I have has a mechanical variable speed setup besides the 4 speed transmission. Also have the rototiller mounted on it and it is a BEAST! Mine has a 16 hp B&S engine.
When I look closer I don’t believe the tractor is under the Wards name. The loader is but not the tractor. I was going by the seller’s description.
The guy who knew everything about the Gilson/Montgomery Ward tractors was on this forum several years ago. He went by the handle "El Toro". I believe I read he passed away around 2017 or 2018. Perhaps some his old posts would have some imformation on that tractor.
The tractor itself looks to be a Gilson or Wards. Same frame and dash design. This is the one I have. Notice that the starter/generator belt cover is the same along with the shifter and the brake lock knob to the right of the shifter.
The design looks similar to the Simplicity built Allis-Chalmers tractors.
Simplicity was even owned by Allis for a time until Simplicity bought the company back.
Simplicity had strong ties with Montgomery Ward as well going back to their rugged walk-behind models which I remember well.
Some of those walk-behinds even had a rugged gear box with a shift lever reachable from the handlebars.
I would guess this is a Simplicity built Wards tractor.
I found this interesting chart while searching around.
Cross-Reference & Platform Sharing Guide
Because they shared exact frame designs, almost all attachments (mower decks, snowblowers, tillers, and plow blades) are completely interchangeable between these matching families. [1, 2]
Simplicity Base ModelAllis-Chalmers EquivalentMontgomery Ward EquivalentKey Vintage Production Era
Simplicity 725Allis-Chalmers B-1Garden Mark Squire (7¼ HP)Early 1960s (Round Hood)
Simplicity LandlordAllis-Chalmers B-10Wards Squire 9Mid 1960s (9 HP Briggs)
Simplicity SovereignAllis-Chalmers B-12Wards Squire 12 (Early)Late 1960s (Heavy Duty Frame)
Simplicity 4040 / 9020Allis-Chalmers 616 / 720Montgomery Ward Twin 201970s (Large-Frame "Super" GTs)
This is a Ward's made by Gilson
