Brass oil junction block (pic)
Winehead
Is there an alternative to buying a $23.50 brass oil junction block + $10 shipping? Just wondering if this is the sort of thing I can find someplace else, and what the thread and fitting sizes are so I know what to ask for. Mine is a cobbled up job it looks like someone brazed together, and not much material left to use a tap on the top portion where it will not thread.
Winehead
It looks like a 1/8 in. pipe thread by 1/4 in. od tube (compression-type) should do ya.
If'n you are us'N 1/4 in. od copper tubing to run the lines, a fella could just solder a 1/4" od. "tee" in the line.
But, stick with the 1/8 in/ pipe thread fitting.
Should be available at Lowes or Home Depot.
HTH John,PA
PS: I gots lotts of 'em, but they are 1/8 in. pipe thread by 1/4 in. od flare. "tee".
Sure you have an option. Optionally.. you can part your tractor with a rag stuffed in the hole and a tarp over it while you decide whether getting the brass oil junction part is worth it!
soundguy
Since you are on the horn.......
Do you have any idea of the Date for that tractor gather'N at the Steven Foster campground area for this year?
I might be taki'N Spring Break about that time from this school-of-hard-knocks and would enjoy visiting the area again.
Thanks, John,PA
PS: I'll be head/N South again about SAT.
I don't have the dates with me, but my MIL has them as we will probably be attending the show with her. I'll call her this week and get the info and post it. If I forget.. prod me about it.
soundguy
As john mentioned.. you could certaintly cobble/solder/braze a gizmo up from some other fittings and pieces that would serve the same purpose, and then fit it to the rest of your system.. etc...
soundguy
Thanks SouNder.
Generally, the week after Stephen Foster, there is another gather'N up the Interstate North a few miles.
The return trip in the Sring requres me to stop by a refrigeration equipment factory in the Wilmington, NC area. That means, return along the coast line to Savannah, GA, then on to NC.
Late March.
Have a new contract here in PA for the upcoming ag. season. Probably the last one before retirement.
John,PA
stephen foster show ANTIQUE TRACTOR & ENGINE SHOW
Date: April 4th through April 6th, 2008. 9:00 a.m. until 5:00 p.m.
Description: Farm machinery representing 200 years of American history. Vintage farm equipment, tractor pulls and races for adults. Children’s games and races. Demonstrations of wheat threshing and shingle milling. Food concessions.
Fees: Free with paid park admission.
Contact: For more information, call 386-397-7005
The fitting is 1/8 pipe thead and the others are inverse flare fittings, same as brake lines. Maybe someting of value at the auto parts store
It must not be all that common. I've been to 2 different auto parts stores, and one plumbing house. They could not come up with an equivalent piece, even looking through the supplier catalogs. They did get 4 fittings together to make a functionally equivalent piece but the length of it would not fit behind the manifold.
I will try to saw off the old piece that the threads are stripped on, and solder an new fitting on as this person did.
Cheers
