c.oawright
My neighbor was bush hogging and more than likely put a tremendous side load on the three point and broke the pin holding the lower link on. It is the pin under the axle housing. He was not aware it had broken. Then he lifted the bush hog and the lower link jammed a hole in the axle housing on the right side. I did not get the model number of the tractor. It is around 45 HP and is about 18 years old and its 4 wheel drive.
I wonder if the hole can be welded. Maybe weld a plate over the hole? It looks like cast iron but it is a casting for sure. Also the pin that broke looks like one piece. I tried to punch it out but it is solid and does not appear to have threads. The mark in the middle is where I hit it with a punch. It looks like a casting as well. Anyone familiar with this?
He drug his old bush hog around the field with half the drive line missing, the lower link lynch pins missing and was dragging it with the top link.
He got a new bush hog and ended up doing this damage.
My neighbor has some situational awareness issues by the way. Age related.
