InterestingWay back when one of the specialty tool companies made thin-walled hole saw specially for that. Maybe an old time auto machinist may have one. This dates back to flathead ford days though so may be hard to find
Everyone else knows that 560 Dennis was suggesting cranking by hand without him needing to state it.^^ Or bend a rod?????
I have had good success blowing the broken piece out with a cutting torch. The cast iron melts at a higher temperature. A hole first, in the broken piece speeds up the process. stanFinally getting serious about swapping engines in my Tractomotive (Allis) TL-10. Donor engine (Allis W-226) came with the machine when I bought it and seller said it was sound but, has been sitting for the three years I've had it and likely for 20-30 years prior, but it does spin. Thought it would be wise to check into it and maybe freshen it up, and then the fun began. Head mostly bolts on but there are 4 studs and head was not about to slip off over them. After soaking for a week with penetrant two of them came loose with my stud remover tool but the other two snapped off. One still had 1/2" of thread exposed and I've welded a nut on it but the 800 ft lbs that my 1/2" drive impact gun develops won't stir it and I hesitate to use the 3/4" drive that would most likely snap it off again. (the small gun on the stud remover tool was what sheared them off initially). What are thoughts on heating the block below the head where the studs are threaded in?
Particularly to the crane operator .Trailer it to your local scrap yard. Chain it down so it won’t lift or move. Give the operator of the electro-magnet crane ten bucks.
This was not intended to be helpful.
