This is something I have been wondering about. Do any of you balance the blades on your brush hog? What I mean is when you remove the blades for sharpening, do you also attempt to get them at the same weight so they will be balanced on the shaft?
I have Woods M5 brush hog and it has the access hole in the top of the deck to remove the blades from the top side. It's very easy to remove them for sharpening which I do on a grinding wheel and a 1" belt sander. Seems that it would be easy to get them both the same weight by grinding some off the edge of the heavy one.
I've never actually weighed them to see how close they are. I'm usually in a hurry when I sharpen them since I've put off my brush hogging for too long.
But, it seems to me that it would be better for the gear box if the blades both weighed the same. I know from reading instructions that you shouldn't put a knife edge on the blades. You use more of a blunt edge when you sharpen them.
I have a digital postal scale so I'll weigh them the next time I have them out.
