buddy did it again
A friend of mine has gotten the bug.In his 50s and never been on a tractor. Has bought 2 in a month. 51 deere B, and a 38 deere A. We need help as he is treading area Im not good in.We had to take the generator off the 51 and have it rebuilt and changed to 12 volt.After reinstalling the generator now the tractor that would start at the drop of a pin wont fire at all.No fire at all at the plugs.Does still have a mag.Nothing else has been messed with to our knowledge.Electric isnt my thing but am understanding of the basics.Someone suggested that the points on the mag are stuck? Does this make sense to anyone. Tractor 2. This old A is a hand start on the flywheel.I know the basics of hand starts: Open cockports,Roll to compression and then pull hard.I can start it,others have but buddy cant. I am looking for any other ways to explain the rolling up to compression factor to someone who hasnt got a clue what we are talking about. Any .02 is accepted. I want him to enjoy his choice of fun and lower his flustration level. Though maybe if he is flustered enough I could get a deal!! No I dont do that to friends. Thanks to all of you in advance.
on the 38A,open the throttle until the arm on the carb just touches the stop, put the choke lever down[there is a line on the choke shaft to tell you how the plate is located],with the petcocks open, turn the flywheel slowly, let the impulse in the mag do the work for you, it will start easier cranking slowly, turn the flywheel a couple of revolutions, then take the choke off[lever up], then turn flywheel slowly and start the tractor.Don't spin a hand crank as hard as you can, it will start very hard.
On the 1951 "B", that's probably not a mag. that's probably a wico model XD distributor. The coil is inside it, and you should have a single 6 volt lead going into it. The points and condenser are probably shot. Or maybe you removed the 6 volt lead from the ignition switch.
Check and see if you have a model XD distributor or just a model X or C mag.
The thing to remember too on that is,it fires at 180 degrees then has to turn 500 degrees before it fires again,so trying to get it to fire on every revolution is futile.
HAHA! I had forgotten about that. Good point... I'll remember that the next time I think it's not gonna start after one revolution.
