MPK
Does anyone have a chart that shows 12v light bulbs for the old tractors that also shows the wattage of the bulbs. I am looking for some like 1141, 1143, 1156, 47, 57,and similar ones. Also substitutions, if possible. Also 6v, if possible. Thanks
The link below is a bit "clunky", but will give you design Volts and Amps data by bulb number.
A helpful local auto parts store may have a GE or Sylvania catalog you could look at... the paper verisons are easier to navigate.
http://www.sylvaniaautocatalog.com/new_sylvania/Search.asp
This next link (.pdf) will let you download a wealth of further information:
http://www.sylvaniaautocatalog.com/new_sylvania/pdf.asp
Sylvania
FWIW, awile back I ran across a site that (as I recall) advertised that it had obsolete bulbs, and my note says it has an online bulb index. If you don"t find your info you might try donsbulbs.com. Good luck.
It's posted here if you search. I mostly got blasted for the idea of larger lamps if or where the charging system would be capable of handling the load.
There are some very high lumen output LED lamp replacements that make the original incandescents look dim. Yet current draw is less than the original incandescent lamps.
