Bunk Blower
Anonymous-0
Wondered if anyone has ever converted a silage blower, for an upright silo, into a bunk blower. I always thought that could work pretty good if mounted to the 3 pt somehow. Any picture or ideas would be appreciated!
we took an old new holland blower set at the end of the trench with a flip spout that would be able to rotate by loosening the clamp and setting it to wear we wanted it . Blew silages all the way to the end evenly about 5 inches deep then packed it whith a small compact 4x4 jd 950. I worked well and the farmall m on it could take the tandem chuck wagons unloading on the high sweep speed filled above the third beater. It did not burn much gas with a 2 foot tall pipe on it either.
Northeast puller
Those Toro 16" and 20" hand held single stage snowblowers with the rubber paddles will do a good job in the feed bunks. Other brands of similar design would work as well.
