bush hog-pull or lift type
DMS
Hello, I have bought a 7700 ford diesel but I own a 3000 ford diesel and have used a 5' 3 point bushog for 12 years. My question is, what is better a 10 foot 3 point hog or a pull type bat wing hog. I have 50 acres to keep up and am tired of hogging 5' at the time. I have a friend who swears by the pull type, he has a 7' pull behind and uses a massy furguson to pull it. Thanks for any replys.
I have a 6700, my brother has a 6610. He was in the market for a 10'er for us both to use. He went with a pull type. After lots of poner'n the only thing we could come up with about a 3pt be'n better was that it would be easier to get up in nooks and cranies of a few spots around the woods. Between the two of us we have some pretty steep ground and figured that the pull type would put less weight on the rear and track better getting up close to fences. He does alot of work in the dark with his job and I work 12 hour shifts at night so I do alot of stuff when I am real tired, I could just see one of us turning to the left real hard and take'n out the fence to right. Also most of what use it for is clip'n pasture so the pull type tracks better on corners.
That was just our think'n.
Dave
If the 50 arces is open go with the wide pull type too save your time. The 3-point is alot easier to get around with.
I've used both and I like my 10' pull behind better. I pull it with a 5610 Ford and it works great. You can pull a bigger hog than you can 3 pt. one due to the weight factor.
I have a big heavy Woods pull type and it earns it s keep . If I can push it over it will chop it up . Sometimes it gets to bangin and jumpin around till it gets things choped up and it dont transfer any of the whamin and slamin to the tractor , When I had a 3pt it would give the tractor a pretty good shake on the bigger stuff .
We have some very steep property so we went with a 3pt lift type. So steep I would feel insecure pulling the lift type up a hill as the tractor's front wheels sometimes come off the ground.
More than once I have pushed down the tractor's 3 pt. lift to push the tractors front tires back down. Of course this may have been due to the brush hog leveraging the tractor so the front end comes off the ground but I have had my tractor's front wheels bobb off the ground without an attachment on back.
We have very very steep property. You flat level ground guys are so lucky.
Thanks all, I am going to look at the 3pt hitch hog. It is used and real cheap compared to a new one. I cannot find any pull types for sale around here.
