Sure will. I have ran a HM planter on a C lots of times, so I don't see why a C mower wouldn't work on the H. I am going to put one on my H if I ever get My H fixed.
George, would you care to email me ,I have a question about the HM planter drive for a friend of mine .Thanks Ralph
Mornin Ralph,
I have the A-21 on my 42 Farmall A. The frame that holds the gear box etc bolts between the final drives. The C-21 is essentially the same mower but it bolts up to the axle housing. Im sure it could be modified to adapt to an H but will require some mods ! I have the Blue Ribbon service manual from Binder Books that really helps with the setup.
scotty
scotty, it doesnt need anything. It will bolt right up on the H or M. He will need the lift cylinder for the H and a short chain to lift the bar.
Mornin George,
Yep, I didnt think it would be to much of a change to go to an H but wasnt sure ! Thanks for the update !
scotty
Hey Scotty. The only thing is the lifting set up for the bar. Someone here posted pics while back of one on an H with a cylinder he had rigged up on the mower itself. Looked like a nice set up. I may look through the archives and see if I can find it. I am thinking about rigging me one like it. Getting hot here now. Suppose to be close to 100.
Afternoon George,
Yep its hot allright, so hot I cant even remember what # mower I have :"(
I have a 16A mower for my 42 A. I do wish I had a mid mount mower for my Super A !
Anyway, just ignore my ramblings, its hot and Im gettin forgetful :")
scotty
16A Sicklemower
I have done this on my M. The problem I ran in to was that the PTO shaft would have to be VERY short. The H may be different, but I could not make a shaft short enough for the M. But, it bolted up just fine.
scotty, they are the same mower for all intents and purposes. I see you have the PTO shield. I bought a whole mower from a guy while back just to get a shield. 50 dollars wasn't too bad for the shield and mower.
Ron, send me an email and I will send some pics of C/SC implements if you like. I have axle mount, front mount, and fast hitch implements for them.
