c water pump pulley removal
TJC in MN
Hello,
trying to put new water pump in, service manual says to remove pulley, I cant seem to get pulley saperated from pump, any ideas, i removed two nuts, still cant take off. thanks
There should be four nuts on the front of the pulley that hold both the fan blade and the pulley on the pump. The two nuts on the side of the pulley are for changing the spacing of the pulley to tighten loose belts.
It has 4 nuts or bolts do not remember which that hold both the fan and the pulley on those need to be removed to pull the fan and the pulley off. Even then they can be a bear at times and a little bit of tapping and working them back and froth are needed to get it off
