Stan in Oly, WA
This is not a math problem. I'm good at math, and anyway, calculating concrete volumes doesn't really rise to the level of math---it's just arithmetic.
What I need to know is the volume of dry components it takes to achieve a volume of 1 cubic yard of concrete, and how to adjust that to come up with a 6 sack mix. A standard general purpose mix is 1:2:3 but that doesn't tell anything about the amount of cement which will be in 1 cu yd of concrete at that ratio because 1 cu ft of cement, 2 cu ft of sand, and 3 cu ft of gravel will not produce 6 cu ft of concrete.
If I can't find some good formulas to work with, I can't think of anything else to do but to mix test batches to try to find out the ratio of dry ingredients to mixed concrete. I don't want to do that because it means having to mix concrete I won't be able to use---it's a waste of materials, and it's hard work.
Thanks, Stan
Thanks, Stan
