California driver written test
> If my memory is correct, my old cars had a single master cylinder. So if a brake line rusts out you no brakes. That happened on my 65 cuda. Brake pedal hit the floor.
I think dual brake systems were required starting in 1966. Yep, it was all or nothing with those old-school brakes.
A few years ago I was driving a brand-new Cadillac. I hit the brakes on a icy road and the ABS kicked in for a couple of seconds, then the brake pedal fell to the floor. Nothing to pump! Plan B was the parking brake, which worked. It seems the master cylinder on those cars isn't bolted to the firewall, but rather attaches with a sort of bayonet connection. The master cylinder must have not been properly installed, and the ABS vibration was enough to knock it loose.
(quoted from post at 06:51:45 05/22/23) What happened to down shifting.... or using engine braking?
Most vehicles are automatics. Very little engine braking.
I know what's coming, some old pharty rant about how everyone should be driving manual transmissions because, "What if their brakes fail?"
Even with a manual, have you tried to get from 10 to 0 using engine braking alone? Without a Jake, it ain't happening.
The vast majority of people will drive their entire lives never having experienced a brake failure. So we as a society should reject a technological advancement because of what might happen to a tiny fraction of people. That doesn't make a whole lot of sense.
The crime is allowing auto manufacturers to make brake lines out of materials that rust away. I would have to imagine corroded brake lines are the cause of the majority of brake pedals going to the floor. Auto manufacturers need to be held liable for that but somehow they are not. They do not even mention brake lines as a normal maintenance item, which they should be, every 10 years, all new brake lines, or make 'em out of something that doesn't rust.
This post was edited by BarnyardEngineering on 05/22/2023 at 08:44 am.
Speaking of jets and brakes reminded me of once on Taiwan a jet fighter lost its brakes on landing.
When the airplane neared the end of the runway the pilot panicked, and jumped overboard and broke a leg. The airplane rolled to a stop in the overrun off the end of the runway, unharmed except for no brakes.
If the pilot would have just hung on he would have been OK.
Not everyone agrees that brake lines should be made of corrosion-resistant materials. (For the record, I agree with you.)
Another opinion
I can tell you that on a 2011 F150, if you lose the front right brake caliper (and all the fluid), you won't have any brakes. The systems may be separate, but the reservoir isn't. Once the fluid is gone, its gone. Downshift and then the trailer brakes. Pumping the pedal didn't help. Kinda lucky that I had a trailer on with electric brakes.
memories of Harold Green warming up for his driving test.
Harold: Uncle Red, if two drivers arrive at a 4 way stop at the same time, who has the right of way?
Red: the guy in the big truck.
Harold, no, it's the driver on the right, Uncle Red. Look in the rulebook.
Red. No, it's the guy in the big truck, Harold. Look in the cemetary.
You go by my rules . YOU MAY HAVE THE RIGHT OF WAY BUT I HAVE THE BIG TRUCK . When your weighing in two to three times the normal gross and your sticking out 4 feet each side the trailer plus being three feet over height keep in mind we DON'T DO FENDER BENDERS , it's more of a game of SQUISH .
Although a good portion of the reservoir may be common, there should be a baffle to separate the lower part of the reservoir so each master cylinder has enough fluid to operate. And even if there was no fluid left in the reservoir, as long as the rear master cylinder is full of fluid it will still work.
My guess is either a) the rear brakes were inoperative for some time, but you didn't notice because the front brakes do 90 percent of the braking; or b) The rear brakes were working just fine, but since the ABS wouldn't let them lock up you didn't think they were working. Regardless, it would be almost impossible to stop a heavy trailer using the rear brakes of the tow vehicle alone, even if they were in perfect working condition.
A good emergency brake has saved me a few times. The old type with the handle and button release between the seats and the foot operated one with the release catch on the dash. If you hold the release in you can apply the brakes without skidding or going sideways. Pressure on the brake until it starts to lock up, let up and reapply. This got me home on a few occasions. Of course you have to increase stopping distance but it does work. My new truck has an electric emergency brake so I guess Ill be pumping the brakes and calling a tow truck.
I remember this question from the CA test: If you park pointing uphill on a street, in what direction should your front wheels be pointed? Anybody who drives in San Francisco needs to know the answer to this.
(quoted from post at 13:28:36 05/22/23)
When did people start calling the parking break an emergency brake? I think that it was recent.
ackwards....parking is the more recent term.
Mark, I never disagreed with CORROSION RESISTANT materials in brake lines. you are putting words in my mouth that I did not say.
What I DID say was that stainless was a poor choice BECAUSE of its being attacked by chlorides - the stuff they put on the roads to melt the snow and ice.
There are more kinds of corrosion than rust (Fe2O3 and FeO), which is basically iron oxide. Stainless ''corrodes'' in a different way. Chlorides leach out parts of the stainless that cause it to fail without ''rusting out.'' Rather it causes the molecular structure of the stainless to fail.
FYI, I did spend 4 years in industry in a factory making custom equipment for the chemical industry. Some of my duties included assembling and hydrotesting high pressure vessels, assembling and testing high pressure compressors and pumps, gauge calibration up to 100,000 psi with a dead weight tester, and going to customer's locations to assist in maintenance of our equipment. Much of this required some knowledge of metallurgy to properly handle the exotic alloys we frequently used.
There is now available some copper/nickel alloy replacement brake tubing that is easier to work with and more corrosion resistant than steel tubing.
I might add that if stainless were a better choice, carmakers would have used it years ago. The difference in cost of materials is very little as compared to the cost of multi-million dollar lawsuits that could result from ''inferior'' materials in a safety system - like brakes.
In conclusion, I say this:
1) I stand by my original statement. and
2) You are free to disagree with me, but please come from a position of knowledge and lastly
3) Do not accuse me of saying things I did not say.
Then we may discuss this at length as gentlemen if you wish.
Dont forget that before self adjusting brakes,you had to manually adjust your brakes once in awhile. If your brakes were not adjusted properly you had to pump the pedal. I remember doing this on my first car because the brakes needed adjusting, it was a 50 mercury.!
I have had 5 pedal to the floor brake failures. 2 were rusted brake lines, 2 master cylinder failures and 1 in a Winstar where the pedal froze, couldn't
apply at all. Never figured that one out.
