Cam on super h
Fresh surfaces makes power.
While your at the cam, have the lifters resurfaced, and rebuild the rocker arm assembly.
Worn rocker arm tips will throw out the valve lash adjustments and will cause all sorts of problems.
As for what to do on a grind for it,,, Stock isnt bad for the Super H if your staying low rpm. Of course, fresh surface on the cam lobes will make better power than a shaft that has 5000+ hours on it. I wouldnt do alot to the cam specs a stock ci, stock rpm, engine. They were pretty good to start with. ChadS
