Can this ring gear be the problem?... be saved?
bilou_sky
My Ford 3400 3 cyl. gas has developed a noisy, screechy-grinding sound for a couple of seconds before finally engaging and starting the engine. This after I took the starter out and sent it for a rebuild because it would only engage after 6-12 tries. When the starter was out I examined the visible teeth on the ring gear. I noticed some burrs and wear on the ring gear (maybe 1/16" max at the gearteeth peaks). I put new high current cables and that didn't help. I'm guessing the next thing to try is the tedious job of filing the burrs off the gear teeth and greasing up the whole shebang... but I don't know if this would be advisable. Maybe the separate solenoid is faulty and not letting enough amps through? Anyone ever deal with this problem?
bilou_sky
That is one sound you cannot ignore..it will just cost you more $$..
You probably have a weak (bad) solenoid on that starter..
That and it may be binding and not engaging easily.
Now, you should examine the ring gear around the complete circumference to determine how badly it is damaged..
If the teeth are not too badly damaged, you can re-profile them (each one), one-by-one..
Quick way to tell, grab hold of the fan blade and pull the engine over 1/4 turn by hand; then try to start it, (with different teeth at the starter engagement point).
You will probably find 4 spots on the flywheel, where the burrs are worst. Try filing, and, of course, rebuild that starter and drive. NO grease, it will migrate to the clutch, or attract more dirt, to hasten the final demise. Some ring geas can be reversed, and used over, sometimes you can get away with rotating the gear 30 degrees, but if you have to split the tractor, you might as well do the clutch, T/O bearing, and resurface the flywheel, install new gear, as well as any seals that are within reach!
Many thanks to BushogPapa, olddog, and DiyDave. Your advice was appreciated and followed. I tried to avoid the labor and time intensive next-to-last resort of filing down the 162 teeth on the flywheel ring gear. I finally caved in and bit the bullet and spent a few hours filing off the burrs through that small access where the starter usually goes... but not until trying some easier fixes:
1. Cleaning the battery connectors and cables, resoldering where they appeared weak.
2. Sending the starter to General Armature for a check and rebuild, where the front bearing and gear were replaced.
3. Installing new Solenoid,
None of the above worked so I finally faced the music and did my best to reface and deburr the teeth... I've since decided that I am not destined to be a dentist! but may have a future as a contortionist! Anyway, the screechy-grindy noise may have improved a little bit, lasting only about 1-2 seconds rather than 2-3 seconds before the starter finally engages to start the motor. I am now ready to do a more thorough check of all cables as well as trying a whole different battery. Any other suggestions?
Thanks again for your input!
