carb for farmall A
I am trying to find a carb kit so I can make that A run better. The number on the carb is DA 91614 or maybe DA 9164A. I have searched this site but can not find one. Serial number is FAA 5283. Thanks for any help you can give me. Bud
https://www.carburetor-parts.com/zenith-k5015.html mikes carburetor is what I like ,this kit has both idle screws .
Mikes carburetor close to you in Washington
Also yesterday has kits just make sure you check the idle screw size in the kit compare to you carburetor
Also the theres a small idle hole in base bowl that has a .04 hole . I use an #80 drill by hand to clean it out . If plugged up it will make you have to choke it to make it run. I have not found any cleaner that will remove the crusted blockage .
the kit will have a new gasket and needle and seat and that will never make it run any better you need the carb cleaned like new it is hard to get the dirt out of some passages soaking just does not get all of it. Buy a small mag lite so you can see in the passages and sometimes need a drill so you can twist it and get junk left at the bottom
I soaked a carb in CLR overnight, after taking everything apart that will come apart. Then blew it out with air compressor. Ran torch tip cleaners through everything. Then 30-40 minutes in an ultrasonic cleaner. Can of carb cleaner spray,air compressor again. Finally came clean. No new parts used.
