WD_Fan07
If I put a TSX 464 carb from a WD45 on a WD would I get more power/better performance or would it get too much gas? I came across a good used one and I"m just curious. I suppose I would need the 45 manifold for full benefit as well.
Probably would not gain enough for you to notice. I did something like that to my Oliver 77 and put a carb on it made for a 770 and I can't tell that it helped any, but in my case I had to because the old one was to far gone to rebuild
Hobby farm
WD45 had more power because of a longer stroke, bigger cubes, bigger pistons of a different design, and higher compression. Changing the carb and manifold will do squat.
