Charlie (KS)
1949 8N, with original carb. I cannot get the darned thing to stop dripping.
I'm not a newbie. I've had this 8N, and another besides, for more than 17 years. This particular 8n can be finicky but has always run well. Over the last 16+ years I have read literally thousands of posts on this site. Thousands.
First thing I did when I got it (DOA, out of a field) was rebuild the carb, per instructions from Dell, Bruce, Bob, Zane, Hobo, and others smart guys on this site. I've been in and out of it many times to clean it, and occasionally replaced parts, but not often.
Last fall it started dripping. Pulled the carb, and the float had a pinhole in hole in it. Replaced it, and nothing else. Still dripped. Tried another old float. Dripped. I didn't mess with it when it was cold but this spring I've been trying to fix it again and it is still dripping. It happens so fast after I turn the fuel on I don't even have time to turn it over before there's gas on the floor.
At this point I have had it off and on a half dozen times. I have:
Tried two new needles from kits from Asia, and a supposed "Tisco" needle and seat, bought at a ridiculous price from a seller who implied it was USA-made, (and I must say it looks EXACTLY like the ones from the cheapie Asian kits, they even measure exactly the same with a mike).
When I installed the needles, I was sure to give each a little twist, but not too hard, to be sure they were seating, then let the installed float drop a few times to make sure the needle was falling freely and it seemed to be.
Even though the old seat looked fine I put in the new one from the Tisco set, as well as the little ring gasket beneath. Made sure it was, as Dell used to say, "honked down" good and tight.
Set the new float height with a 9/32 drill bit until it seems I could not get closer to being perfect. I have to say, in the past there always seemed to be a lot of wiggle room with this--it just had to be close but this time I've tried a lot harder.
Shaken the carb once assembled to make sure the float was not hanging up somewhere. It moves freely and seems fine.
Checked that the new float has no hole. It is fine.
Banged on the side of the carb with a mallet.
All I can think of is the needle isn't sealing or is misaligning and hanging up on the side of the seat.
So, is there's anything obvious I could possibly be missing, other than in three tries I have not yet gotten a needle that will seal?
I have rebuilt and tuned SU carbs on my 1960 Austin Healey and, despite their reputation, they have never ever kicked my butt like this!
Have read practically every post on this and don't see what I'm missing. Any ideas? I'm tearing my hair out and I don't have much to spare.
Thanks!
Charlie.
This post was edited by Charlie (KS) on 04/28/2023 at 07:15 am.
Thanks!
Charlie.
