muench
Any suggestions on what carb i might use on my farmall h i have it stroked longer rods and oversized pistons just wondering on some ideas
The best carb i could suggest is an upper half from a 300,350,400,450 with the venturi and bowl from a c-301 6 cylinder( 715 combine or 806) that will let alot more air thru and a better bowl set up.
Matt
where did you get the stroker crank and rods. not to many people will share their parts sources. are they custom pieces or parts sourced from other tractors?
300-450 bowls are pretty much the same as the 6 cyl bowls. 300-450 carb will help with the idle quality in a stroker if the M carb isnt letting the idle screw off the seat without stalling. M carb with a 27 is more tham plenty,,, a 300-450 carb with a 25 is a real decent setup for a H-350. Too big,,, it wont lug. Chad
Chad I sent you a few emails but you must have not gotten them.....I have a 300 carb that needs your magic touch......Could you either send me an email or give me a number to call........Thanks
574-893-7437. Email: [email protected] WWW.TheTractorShop.com
Get em in, Im setting up to do a bunch of carbs, soon as the weather quits raining for two or more days!! In one week, Im sandblasting over 25 carbs to build, and getting parts gathered to build em all and get em sent out. ChadS
