kendal
i have a carb and was wondering if anyone can help identify it to get a rebuild kit. it came off of a farmall 300 that was farm fuel. the part # is 363741R91. the carb looks identical to the gas carb on my dads 300 farmall. havnt compared part# yet. thanks.
363741 R91 is a distillate and kerosene caburetor for a 300. 363741 R91 is a early 300 carburetor that has a different throttle body and some other parts compared to a gasoline. Also different than 363741 R92 and R93 that replaced R91.
Didn't say in the other post, but if you just want gaskets and a needle valve and seat a M or SM kit will work. Your carburetor has more parts common to those tractors than to most 300 and 350 carburetors.
358065 R93 is one I'm looking for info on.
It fits Super H thru 450.
The throttle body has some unique differences.
It is the exact same casting as the 300-450.
It has the area for the flange located idle adjustment screw,
where the 300-450 had their Idle screw adjustment location in the flange, its not been drilled for the passages, it still uses the old M style Idle circuits with the large brass adjustments screw.
Its stamped 5-54 on the manifold gasket surface.
Dad bought it when Alfords' Implement in Laketon sold out and had their auction. They had alot of IH stuff back then. ChadS
