On my 49 front mount 12V, the tractor seams to run better with the choke pulled out about a 1/4 inch. I have installed a new set of points and adjusted them to .015 new plugs al437s gapped .025, drained and flushed the gas tank and all 3 screens pulled the carb apart which I think is the zenith carb and made sure everything was cleared out blew with air and found no blockage. Checked float height and reassembled. Still have same problem. I can take the main jet all the way out and the thing runs better. Do I need a larger main jet or is there something I am missing. And yes I pulled the plug on bottom of carb and got plenty of fuel. I am in Houston Tx at sea level.
