Anonymous-0
At first blush, erratic clutch pressure. After much observation there is a pattern.
1. Constant below normal (260-290) operating pressure--it jumps immediately to 200psi indicated upon starting engine and remains at 200psi indicated from 800rpm to 3000rpm. Shifting ANY control lever causes psi to instantly drop to either zero or 100psi indicated.
I say "indicated" because the tractor continues to function normally at either zero or 100psi with the one exception that at zero it does not turn as well as it does at higher indicated psi.
2. Shifting either the HI-Lo or Forward-/Reverse levers back and forth slowly after the indicated psi has dropped to either zero or 100 will cause the psi to instantly jump back to 200.
3. These "jumps" are exactly that. The psi does not slowly rise or fall--it jumps instantly. Engine rpm has no effect on the indicated clutch pressure.
4 I have had both the pressure regulating valves apart and have found nothing wrong (Torque Converter pressure regulator valve and Clutch/Transmission pressure relief valve). All filters have been replaced AND the oil was clean and without water--no debris, metal parts, dirt, etc. in any of the filters or housings.
5. Low initial indicated psi may be the charge pump (I have a new one) Zero indicated psi is probably not correct, as the tractor should not move at zero clutch pressure, and it moves rather handily at "zero". It will even perform a counter-rotation turn at zero indicated psi.--just not quite as well as it should.
6. This is a military surplus machine with military refurbishing. It looks NEW. It has 390 hours on the rebuild by the military. The military part of all this is important because Case can't find the right parts, due most likely to different specs for the military than for civilian tractors. (EXAMPLE: This machine is supposed to have a Case 401B 6 cylinder engine, but it has a Detroit 4-53 engine and related parts which Case can't find in their service manuals and parts books.)
7. The Winch works fine. It operates off the left side forward/reverse drive clutch, but not like the book says. Instead of a 3 position (F-N-R) Winch lever and in or out by the clutch, it has an in or out Winch lever and direction is controlled by the forward/revers lever in the transmission control lever tower. But the fact is the Winch is strong, indicating there is nothing wrong with the clutch.
8. The way the indicated clutch pressure snaps back and forth between zero, 100psi, and 200psi makes it appear that some kind of shuttle, or valve is snapping open or closed when gear levers are moved. I suspect the transmission control valve or some related part I can't find since the pressure changes occur only when the control valve levers are operated. (There is, I believe, some FLOW impairment when the pressure is at zero because the tractor can lose momentum pushing a big load or climbing up a 45 degree pile. Under those conditions I can encourage better performance by more throttle--without changing the indicated pressure. Flow loss could fall back on the charge pump, of course....) Still, that does not explain the jumping around of the indicated clutch pressure. 200psi to zero and back to 200psi are big jumps to be accomplished instantly.
9. Does anybody know what is going on with this machine? I have owned and operated Caterpillar D8s and D6s and a couple of International TD14s in the past 50 years, but this is my first Case. I don't know its idiosyncrasies.
