I recently got a case 1816c skid loader with an Onan B43M engine. The guy I bought it off said it had been sitting outside for about a year since it had quite running, they thought it was only running on one cylinder then. I cleaned and corrected the points gap and got it started up, it was running rough so I checked the cylinder compression (50 & 80 PSI). With the low compression I went ahead and checked the valve clearance which was way to tight, so I reset it per the specs. This bumped the compression up to 80 PSI in both cylinders now. I also cleaned and rebuilt the carb then. Now I have it all reassembled it starts right up and runs really smooth with no load on the engine, but when I engine the hydraulics it bogs down to about half RPMS and wants to die. The Onan carb is a fixed high jet so I can only adjust for the low idle, could this be a problem with the governor, intake sucking air???? Thanks for any help
