case 1835b uniloader charge psi light
nmliving
Having a problem with my 1835b skidsteer. I keep intermittantly getting a charge PSI and charge filter light on the gauge panel. When this happens I lose hydraulic pressure to both the drive motors and bucket/ lift rams.
I have replaced both filters and changed out all the hydraulic fluid with no improvment.
Any ideas? I don"t have a service manual or owners manual for this thing so any ideas would be appreciated.
Thank"s Bruce (ATL GA.)
(quoted from post at 05:00:46 09/11/07) Get ready to spend a lot of money on a new pump.
Wrong, Wrong, Wrong- This is exactly why you don't listen to a "Guest".
I researched this further because I had the same -dead-in-the-water symptoms with my 1835. It's a Hydraulic Fuse that cuts all fluid movement when there is a mild to moderate hydraulic leak. Research PSI Hydraulic Fuse for further details-
http://www.predatorsystemsinc.com/fuses.html tells it all!
Take a moment to read and you'll learn a lot like I did. Now all I have to do is locate this on my machine and I'm back in business and no, not shelling out $$ for a new pump.
