Anonymous-0
Trouble started when picking stones, the engine died almost like when you snub it. Tried to restart, engine would turn over but would not fire. I let it sit for about an hour and it restarted, I moved it up to the shed and changed the fuel filter; tried to restart and same problem. I let it sit overnight, and it restarted without any problems so I just left it run for about 30 minutes and then I moved the throttle and the engine died. I thought it might be the ignition swith so I installed a new one. I used it yesterday to pick some more stones and the same problem started, engine dies, leave it sit for a couple of minutes and it restarts and run long enough to get back to the shed, then move the throttle forward and the engine dies. I then installed another fuel filter and bled, the transfer pump is working without any problems, got it restarted and left it run for an hour, then move the throttle and engine dies. Has anyone else had a similar problem? Any suggestions on what to look for next? Thanks Ken
