The foot clutch rod end may have broken off or pulled through a worn out or rusted out socket. The yoke (fork) pivot can break loose also.
Aside from the rust the tractor is not supported well enough. You're taking a change on bending the drive shaft and end up scraping the tractor. The two parts you are splitting are very heavy, they need to be come apart supported and go back together straight.
You should push it back together and move it to concrete or other solid surface. If the engine crank hasn't been turned the hyd pump shaft splines will side right back into the pressure plate hub splines, otherwise you will need to turn the crank until they mate. Pulling together with the fasteners is ok if you are sure the splines are meshing but do not force it.
When on a solid surface, crib the torque tube and roll the engine part away. Floor jack is adequate but a shop crane is better on the engine end. That isn't going to solve a rust problem but make it a lot easier to get apart/together and w/o damage.
This is the way I do it. Hydraulic table under the torque tube and shop crane on the engine. Floor jacks are an adequate substitute for both, just less flexibility and more time consuming.
