Case 400 water pump kit needed
This message is a reply to an archived post by Kevin Meier on August 11, 2008 at 14:13:21.
The original subject was "Re: Case 400 water pump kit needed".
i tore down my water pump for my big 400 and i need rebuild kit for it also do you have one for a 1951 case dc thanks
if the carbon seal is not cracked D series water pumps can usually be renewed with out buying any parts, you just need to build up the pitted area of the shaft with bronze, turn it down on a lathe and reface the seal surfac of the housing with a lathe
