case 411 wont start
Anonymous-0
I cant get my case 411 started. when i try starting it, it fires once or twice. I put the choke on and it is still the same. i drained the carb thinking that it was flooded, but that didnt work either. what could be the problem???
You did not say where you drained the carb. If you took the plug out of the base of the bowl and nothing ran out you are not getting gas from the tank. If it was flooded usually gas will drip out of the hose connecting to the air cleaner.Disconnect the gas line at the carb and see if you have flow. If you have flow, Check the ignition system. There has been numeros posts on tractors not starting. page back through this forum for the past few days Many,Many helpful posts.
i know that i have gas flow, because when i turn the gas shut-off on, gas keeps comin out. some guy told me to rotate my distributer 90 degrees because it was backfiring. there is no more backfiring but i cant get the engine to turn over for more than a few seconds. wtf is goin on with it?
ok, were you able to check the condition of your plugs? Do you know that you have a good bright spark? Tough to say with out looking at it. Is the starter turning the engine over fast enough for it to start like usual? May be a carb problem, or something like a bad ignition coil. Hope you are able to figure it out. Hope this helps
i did check the plugs. they are pretty new and they look ok. the starter makes the engine fire once or twice and thats about it.
