Nosepicker
I have a case 530, not entirely sure of the year, that the power steering does not function on. I have a case manual however it does not address the steering set up I have. What I know is that the rubber line from the pump to the filter canister had a large hole in it. Before finding this i added fluid to it and that is how I found the leak. I am tempted to drain the old fluid that remains and replace the hose, refill and see if it works. What I don’t know is how the system functions. I have a large steering box that drives the pitman arm to a single steering cylinder that has two hydraulic lines to it. These go to the pump and filter canister respectively. If anyone has a diagram of this steering system I would appreciate being able to see it. If you guys have any ideas on what to look for as far as problems I am open to listen. The tractor runs great, loader works great, I just need to sort out the power steering. She needs a bath and will likely be torn down this winter to reseal and paint.
