gschroeder
I have a 1980 Case 580C backhoe with a starting issue. When I turn on the key, and push the start button, I only get a click. However, if I turn the key on, and manually jump a wire from the positive terminal on the starter, to the solenoid, the starter cranks the engine over as it should. Any suggestions on what the problem is here? I did replace the starter, but that did not solve the problem. Also confirmed both batteries are OK as they crank the engine over just fine when I manually jump a wire from the positive side on the starter, to the solenoid. I also removed the starter push button on the dash that cranks the engine, manually jumped the 2 wires on back of it, but still just get a click. Thank you in advance for your advice. Thank you
