This message is a reply to an archived post by Jimb2 on June 12, 2010 at 19:11:01.
The original subject was Re: 585 loader hookup.
I have been researching a loader valve / SCV problem on my Dads 1990 Case 585 which has the OE power beyond block on it. The loader is a Kelly loader with the hydraulic supply plumbed into the port right behind the port that the front part of tube #38 is connected to on the power beyond block. The return is plumbed into a port on the bottom of the transmission housing. This is how it was set up when he purchased it new. The SCV had to be in the up position for the loader to work and I recently found out the SCV will not raise anything unless the loader bucket valve is deadheaded in the up position (easiest valve position to deadhead). In the hope that the loader and SCV would finally function separately and based on a post by Jimb2 on Jun 12, 2010, I removed the auxiliary valve tube #38 and capped the 2 open ports. The loader valve now functions without the SCV in the up position. However the SCV still will not work unless the loader bucket valve is deadheaded. I have looked at hydraulic schematics for hydraulic valves and how power beyond is plumbed in and cannot figure out how the Case 585 auxiliary hydraulics is set up especially since the power beyond block is next to the transmission and the SCV valve is after that. Nor can I figure out how to solve my problem. Can anyone help me out with what to do next? Thank you, Roger M.
