Anonymous-0
I have a 67 CK gas 730. The gear that drives the tach on the distributor shaft is worn. Since I want my tach to work, I'm looking for another distributor. Unfortunately, my distributor does not have a tag or part # on it. There is a 730 in a junk yard near me and it has the distributor in it but it does not look the same. Mine is held in by two bolts with washers that screw into the block on each side. The one in the junk yard looks like the base is cast and is pressed into the block, with a single bolt holding the distributor into the pressed in cast. Are these distributors be interchangable? Any advice is appreciated.
Nate
