(quoted from post at 07:52:02 04/28/22) I dont have one real good answer for your problem, as
I have done battle with my 930 to keep it cool over the
years also. To me, there just isnt enough radiator on
these tractors to be able to afford anything less than a
perfectly clean rad. I did take my rad out to a rad man
and had it cleaned, and it made a world of difference.
But nothing beats blowing them out with compressed
air frequently. Just a word about the lower rad hose. I
found the fan belt ran very close to the hose, close
enough that from time to time, the belt would actually
rub the hose enough to wear a hole through, even
though the belt seems tight, and doesnt touch when
the tractor isnt running. I split open an aluminum pop
can, a placed it around the lower rad hose, held in
place with a gear clamp. Did this probably 8 years
ago, solved this little problem. I think the new rad
hoses are just a tad thicker than the original.
You could also put on a fan with more blades to
increase air flow, something I have considered, but
not tried yet myself. Strangely enough my 1030 never
offers to heat up. Same basic unit.
(quoted from post at 06:55:39 04/28/22) Opening yourself up to a deluge of rad cleaning techniques here, but here's my $.02.
If you want to avoid replacing/re-coring the rad, use only clean water to flush, everything else can eat it.
The block can probably handle a cleaner, but don't run it thru your rad. I would do it before you replace water pump, etc.
(quoted from post at 09:21:04 04/28/22) Ive pulled an old Case 930 CK with 401 diesel 2 range, 4 speed out of the barn thats been sitting 20 years. Before parking had pulled a round baler. Hadnt been very well maintained judging from air cleaner, filters, general condition. No gauges working.
Intending to run a small hay grinder (55HP) to mix feed. Fired right up after all those years sitting. After a couple new tires, found the PTO was not holding. Rebuilt clutches. Hooked up to grinder and ran hot, boiling, inside 15 mins. Cooled down, re-topped, and same. Pulled thermostats, Looked bad but actually function, opening at 180. Replaced temp gauge with a mechanical gauge. Left out thermostats. Cranked and took a while to get to 160 (20 mins) Ran up and down the road at WOT in H2. Temp finally got to 205 in another 20 mins. I stopped at that point thinking itd continue to boiling. Let it fast idle for 5 mins and only cooled 2.5-3 degrees. Thinking was going to run hot, pulled the radiator. It looked bad on inside as I can see but maybe a couple gallons from a water hose held in inlet passing through. Can see through fins in some area but not all. Also the water pump suction hose is soft and is not wire reinforced (maybe the wires are completely disintegrated?). Planning on changing the water pump, thermostats, hoses and getting radiator cleaned. Looking for any recommendations going forward on cleaning radiator (not many shops left) and engine flushing, or any other relevant topics. Thanks.
(quoted from post at 07:04:23 04/29/22) As many have said already - replace the radiator. Will be the best $600 you can spend. Had a 930 that we fought with for years running hot and over heating. Ended up cracking heads multiple times. Save yourself the headache and money - just replace the radiator.
Matt
