So I saved a bunch of manuals from the recycle/fleabayers in the thought that some of you might like them. Don't think I will sell them, but if somebody needs a copy or certain pages, I will try and get them to you. Most are parts manuals (more than I thought I got), a few operators and a few services ones. Email is open, or if you can't get ytmag mail to work, then it is my username followed by @comcast.net.
Here is a list of what I have:
Parts Manuals (followed by manual #):
Model 350 Narrow Row Cultivators - #570
Model "I", "IR", "IS" two row corn picker - #E169
Front mounted Planter Attachments - Buster and Runner type - FSHP2B-FDHP2B, FSHP2R-FDHP2R for "H" cultivator. FD2PCF for DC and FS2PCF for SC tractors - #A463
Case-Osborne Regular and Short Corn Binders - #R811
Model "H" Stalk Shredder - #B513
F127 Standard Mower - #R624
Front Mounted Middlebusters FD3, FS2 - #A459
Tractor Mounted Beet and Bean Planters, Narrow Row cultivators, Bean Cutter attachment, Beet Puller - #A451
Model "DI" Tractor - #B257
"WR", "WRA" Wheatland Disk Plow and seed attachment - #D439
Low Wheel Seedmeter Steel Hopper Fertilizer Grain Drill "LF" series ('48-'50) - #B469
20 Bar Steel Thresher and Thresher Attachments - A155
Steel Thresher (22x36 and 28x46 after 70933 - #132
Model V and VA Frame Master Frame - #RI65 (2nd edition)
"VCMB" one and Two Bottom Plow - #RI154 (1st edition)
Model "E" 2 way plow for VA series Eagle Hitch - #RI229
Model RC Tractor - #C182
Model "E2B" Bedder and "E4C" Bedder Cultivator for VA Series w/Eagle Hitch - #RI209
Model "J" Forage Blower - #B261
"VC4P" V series and "FVA4P" VA Series narrow Row planters - RI159 (1st edition)
CC Narrow Row Seeder 4,6,8,10 rows
NA series balers
"O" Series Field Tillers Tractor Drawn - #A466
Model "NL" and "NPLM" baler and Model "AF", "ACF", "AHH" single Cylinde rEngine - #D203
Model "EH" Portable Elevator - #528
TA7 Power Mower Semi Mount - #A496
WP, WPA, WPH one way disk plow and seeding attachments - #B464
H Series Cultivators - 2 and 4 row for DC/SC tractors - #C460
Industrial Mower Model "VAI" 5 - #A483
"VW", "VWT", "VWTA", "VT" Farm Gear - #RIB87
Roller Packers - Eagle hitch and drawn - #D391
Two Way Turnover Tractor Gang Plow - #A475
Model SI Tractor - #A252
"FV2B", "FV2C", "FV2R" Planters - #RI155 (1st edition)
Model "B" 12 windrower - #C224
Model "I", "IR" and "IS" Two Row Corn Picker w/Rear Deliver Elevator and Sheller changes after #550000 - #E169 (Supplement to parts catalog E169)
Eagle Hitch Spike Tooth Ubar lever harrows Model BE, CE and USE series- #A700
All Steel Corn Binders R7 and R8 series - #456
Model "A6" - "A" combine - #E191
Eagle Hitch & Remote Cylinder attachments for VA series - #RIA192
Model H Series Stationary and Portable Hammer Mills - #RIA144
Model "C" Forage Harvester - #B250
Case Magnetos - #504
Hydraulic Adapting Equipment - #489
T8 2 Wheel Tractor Spreader - #B485
22x37, 28x47, and 32x51 threshers - #E177
#40, 41, 42, 42P Two row planter - #D403
Wire Threading Attachment for NAP baler (supplement to C216)
Seedmeter Steel Hopper Grain Drill and Fertilizer Attachements - #B441
Service Manuals:
Case Hammer Mills "H", "HA" and "HB" series
Grain Drill L series
Model 140W, 160W and 160T Automatic Tie Hay Balers
LP-Gas equipment on Case LA series tractor
VA Series Hydraulic Pump
Low Pressure Hydraulic Pump - VA Series Eagle Hitch (supplemental)
Model S Series tractor Liver Power take off Eagle Hitch (supplemental)
Model K2 combine rework instructions
"B", "BL", "TOA" series plow
Attachments used to harvest edible beans (install instructions)
Model S tractor and engines
Model D Series Tractor - Live PTO and eagle hitch (Supplementary)
Operators Manual:
Model Q Crop Cutter
Model M Combine
Model CO offset Disk Harrow
Mounted Cotton Harvester model 201 (stripper type)
Fertilizer Distributor Model U
Model S series Tractor
Model IS Corn Picker-Sheller
Agricultural Mower Model 15
Misc:
Case Service Tools
Service bulletins for VA Series
Service bulletins for Combines
NA series balers
Service Manuals:
Operators Manual:
Model Q Crop Cutter
Model M Combine
Misc:
Case Service Tools
