Case C rear wheel removal
Farmphil
I need some ideas for removing a rear wheel on my C. We have beat on it, pulled on it, heated it and done all three. Anyone have any ides? Thanks!
Hi Farmphil,
Hopefully this will help you. I have removed several wheels this way. I use a 3/8" logging chain and wrap it around the back of the cast part in center of wheel 2 times. Then I use a 20 ton bottle jack with the piston part against the axle and the chain arcross the base of the jack. Make sure the piston of the jack is toward the bottom so it will get fluid. Then start pumping. It should pop then be loose due to it is a tapered shaft.
Casenut has the right idea. Don't be surprised if, when you get it off, you find a small spot of rust somewhere on the axle. A friend of mine had that happen to him about 20 years ago.
In the toolkit that came with my Dad's C (new in 1936) there was a cap that screwed on the end of the axle. The cap had to be screwed on until the inside was snug on the end of the axle. The opposite wheel is jacked off the ground and the tractor is belted off the wheel still on the ground by hitting the cap with a sledge hammer.
It is not easy, but it does work.
Like Bob said. I have removed wheels off of motor graders like he said. I would get a nut like they had to hold the wheel on the axle. Weld a solid shaft or square bar on it. Screw it up tight on the end of the axle with the washer off so you have slack between the wheel and axle. Jack the other wheel up and leave it up. Take a large hammer the bigger the better and show it who is BOSS!!! It will come off. This a lot better than a puller. Good Luck.
I don't know if your C is on steel or rubber, but here is how I removed the steel wheels off the back of a Case C. There are two large threaded holes either 5/8" or 3/4" in the hub on each side of where the axle comes through. They may be filled with dirt and rust, so you might have to run a tap through them to clean them up. You need to find a hefty chuck of steel about 2" thick and drill two holes through it the same distance apart as the two holes in the hub, make sure the holes you drill are larger than the holes in the hub, around 7/8". You need to jack up the tractor and take the large castle nut off the end of the axle. Then hold the 2" chunk of steel over the axle while pushing a bolt through each of the holes you drilled in the steel bar and threading them into the hub. The axle sticks out farther than the hub you can screw the bolts tight and hit the bar over the end of the axle with a hammer to jar it loose. You may need to do it several times, and re-tighten the bolts, but it will pull it loose.
