PICTURESi took a DC ENGINE OUT OF IT. I PUT IT IN 50YRS AGO THEREBOUTS, AND HAD NO PLATE OR PROBLEM PUTTING IT IN. THE PLATE ON THIS ONE, as mentioned has around 6 bolts in it that athe heads are flush into the back of the plate. i think that the plate fits inside on a shaft, likely the crankshaft
So do I. I've taken hundreds of pictures with it.GOT A FLIP PHONE. OLD STYLE.
Turbo DC? Tell us more about that!!!!Good thought Klyde, My thoughts are that if he has an engine out of a later DC he would think it entirely different , but even still, that, stuff will all unbolt and allow the stuff he has to be installed on the engine without any problems at all., Many on here are probably not familiar with the prior style clutch with the lined plate that bolted to the flywheel and the cast plates that sandwiched it with the fingers that rode out a tapered cone to supply pressure to clamp the rotating plate, but either way, the input to the transmission shaft works with either, they take the same flywheel pilot bearing. We used the old clutch on our Turbo DC back in the 60s until heat got to it and it warped and did not want to release so we updated to the later style clutch which never gave us any problems. I am gonna guess and maybe someone has access to the info, but I think the clutch change probably occurred around 1944.
That's the key right there. I can almost guarantee the phone is capable of transferring pics to other devices. Do you have any kind of computer? I certainly hope you're not using the internet on your flip phone lol. In general terms, you plug the phone into a computer (desktop, laptop, tablet), transfer the files to it, and upload them to the internet from there. It just requires the correct cable. If you can tell us the make and model of your phone, someone can possibly provide more detailed info.but as far as i know, i cant send them anywhere
