Case CC Paint color
AJ in IL
does anyone know the correct grey for a CC. I had a 30' that was dark grey, a 37' that was massey grey and just looked at a 29' that was a really light greyish white. I thought i heard that the correct grey is no longer available but whats the closest? I think the dark grey with red and white lettering and pin stripes looks best but i would like to get it as close to original as possible
I've seen the original color referred to as "LC Grey" probably because it was on the L and C series tractors. Not sure if anyone has it or what the paint codes might be. It is possible that external_link might have it. I'm finishing up my '37 CC and I used modern Case Construction Equipment Grey. Compared to original paint found on the tractor, it is pretty close and it looks good. If needed, I can get the number for the shade that I used as there are four different shades. It is also readily available at most ag and construction Case dealers.
AJ Here is a Dupont paint color
DuPont Tractor Colors
(R & UNSTYLED RC)
THE ORIGINAL COLOR USED ON THESE MODELS IS STILL
QUESTIONABLE. EXPERTS SAY THAT FOR NAAGRAY IS
CLOSE TO THE LC DARK GRAY CASE B13017.
1937 RC GRAY LS136
CASE GRAY 24938 +
(MED TO LT DARK GRAY)
OLD GRAY 98620 D (55803)
1930 MODEL L GRAY C9812
(1998 gm 314c)
LC GRAY 7812
(DIT CROSS 32974
Thanks guys , that helps a lot. It still seems that when you view pics of the older cc's on the web there all shades of gray. I like the dark grays the best!
