Case IH 255 Compact tractor Hydraulics
Anonymous-0
This morning I checked the fluid levels prior to starting it and hydraulic fluid was low. I started it and drove it to other side of property where I keep diesel fuel, oils, etc. and shut it off. I noticed that the three point lift didn't lift as high as normal, but I figured that was due to being cold. I filled the fluid, started the engine, and found that both the power steering and 3 point lift both stopped working. I can only assume that they both work from the same hydraulic pump. I have no idea where it is, what it looks like, or what to check. Any help in the way of information would be most appreciated.
