case ih mxm 120
Just a couple questions, on a mxm 120, are the remotes standardized so that pioneer fittings work? Also, is it common on these modern tractors that if you slide the lever in the cab that the hydraulic fluid will run out the remotes if nothing is plugged into them?
Pioneer couplers are what you need. And there shouldn"t be oil leaking when you move the lever, i expect there seal is wore in the coupler, may need a new one, not sure if the inner seal is replaceable (i"m guessing not)
