Case vac question
grandpa Love
Will a Case vac run a New Holland
sickle mower?
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto39509.jpg">
The Ford handles it, but it could
be a pain to take it off so I
could run the baler.
Your 601 will handle the sickle bar mower. And yes a VAC should also handle it. So are you looking at a VAC or did you buy one already?? Shoot I have a VAC I'd sell you. Needs some TLC but I have had it running
I assume it has the "Eagle" hitch? The interesting part about "running" a NH mower is attaching it to the tractor with that unique top link apparatus. I think it would fit a VAC OK.
We once ran an Allis Chalmers 5' combine with a VAC back in the day, I don't know why one wouldn't handle a sickle bar mower.
The Stockton hitches were powered by the pump in the belt pulley housing, not a pump up on the timing gear housing of the engine. I doubt his mower would hook to a stockton hitch, but it will fit nicely on the Eagle Hitch VAC's-------Loren
Well since I have not tried hard to say if it could be used with the Stockton hitch or not and since I do not have one of those mowers I can not try it
