LGoff
Just bought a 1987 D3B. The bevel gear oil doesn't even touch the dipstick. What weight gear oil do I use? Just any type of gear oil? Also, besides the Cat brand 10W hydraulic fluid, is there another brand that is cheaper but will work?
Ask for eqivilent to Cat TDTO4 for powershift trans, bevel gear or steering clutches if they are oil type. Oil clutches have a 1/4NPT plug near the final drive plug to check level and big fill plugs on top cover. Use 50 oil in the final drives. Use diesel engine oil in engine and hyd system.
Later Bob
Yes, diesel engine oil has more zink in it and will increase hyd pump life too. Good rule of thumb, use TDTO4 in anything with a clutch in it. Powershift trans, wet steering clutches or wet flywheel clutch
Later Bob
It's just hard to find a gear oil that is lower than 75W or 80/90W. I did find a 50W at the local NAPA, but it's synthetic and it's $120 dollars for five gallons.
Not gear oil--the manual calls for sae 30 motor oil for the bevel gear,track rollers and final drives. Also sae 30 oil for the engine for a temperature range of 20* to 120*--otherwise lighter oil for temps lower than 20*
Cat calls these oils CD mil-l-2104c
